  • Wolfspeed WolfPACK™ Silicon Carbide Power Module Family
Silicon Carbide Implementation Made Simple, Compact, Reliable
Wolfspeed has launched a baseplate-less module family to meet the requirements of medium power applications, providing solutions across the power electronics continuum. Wolfspeed WolfPACK™ modules are a great choice for designers who want to increase efficiency and power density in a compact, industry standard footprint. The family of modules provide an excellent solution for fast design implementation, scalability, long term design support, and lower assembly overhead. Wolfspeed WolfPACK modules are currently available in half-bridge, six-pack, full-bridge, and T-type configurations all with the option of pre-applied thermal interface material.
Composite image of two Wolfspeed WolfPACK™ Silicon Carbide Power Modules stacked on each other.
  • Videos
  • Videos
No filters selected, showing all 36 products
Wolfspeed WolfPACK™ Silicon Carbide Power Module Family - Filter By
Configuration
Module Size
Pre-Applied TIM
CAB004M12GM4
GM
Half-Bridge
200 A
4 mΩ
62.8 x 56.7 mm
No
CAB004M12GM4T
GM
Half-Bridge
200 A
4 mΩ
62.8 x 56.7 mm
CAB006M12GM3
GM
Half-Bridge
200 A
6 mΩ
Gen 3 MOS
150 °C
62.8 x 56.7 mm
No
CAB006A12GM3
GM
Half Bridge (AlN substrate)
200 A
6 mΩ
Gen 3 MOS
150 °C
62.8 x 56.7 mm
No
CAB006M12GM3T
GM
Half-Bridge
200 A
6 mΩ
Gen 3 MOS
150 °C
62.8 x 56.7 mm
CAB006A12GM3T
GM
200 A
6 mΩ
Gen 3 MOS
150 °C
62.8 x 56.7 mm
CAB008A12GM3
GM
181 A
8 mΩ
Gen 3 MOS
150 °C
62.8 x 56.7 mm
No
CAB008M12GM3
GM
Half-Bridge
160 A
8 mΩ
Gen 3 MOS
150 °C
62.8 x 56.7 mm
No
CAB008M12GM3T
GM
Half-Bridge
160 A
8 mΩ
Gen 3 MOS
150 °C
62.8 x 56.7 mm
CAB008A12GM3T
GM
181 A
8 mΩ
Gen 3 MOS
150 °C
62.8 x 56.7 mm
CAB011M12FM3
FM
Half-Bridge
117 A
11 mΩ
Gen 3 MOS
150 °C
62.8 x 33.8 mm
No
CAB011M12FM3T
FM
Half-Bridge
117 A
11 mΩ
Gen 3 MOS
150 °C
62.8 x 33.8 mm
CAB011A12GM3
GM
Half-Bridge
141 A
11 mΩ
Gen 3 MOS
150 °C
62.8 x 56.7 mm
No
CAB011A12GM3T
GM
Half-Bridge
141 A
11 mΩ
Gen 3 MOS
150 °C
62.8 x 56.7 mm
CBB011M12GM4
GM
Full-Bridge
100 A
11 mΩ
62.8 x 56.7 mm
No
CBB011M12GM4T
GM
Full-Bridge
100 A
11 mΩ
62.8 x 56.7 mm
CHB011M12GM4
GM
T-Type
100 A
11 mΩ
62.8 x 56.7 mm
No
CHB011M12GM4T
GM
T-Type
100 A
11 mΩ
62.8 x 56.7 mm
CAB016M12FM3
FM
Half-Bridge
84 A
16 mΩ
Gen 3 MOS
150 °C
62.8 x 33.8 mm
No
CAB016M12FM3T
FM
Half-Bridge
84 A
16 mΩ
Gen 3 MOS
150 °C
62.8 x 33.8 mm
CCB016M12GM3
GM
Six-pack (three-phase)
50 A
16 mΩ
Gen 3 MOS
150 °C
62.8 x 56.7 mm
No
CCB016M12GM3T
GM
50 A
16 mΩ
Gen 3 MOS
150 °C
62.8 x 56.7 mm
CCB021M12FM3
FM
30 A
21 mΩ
Gen 3 MOS
150 °C
62.8 x 33.8 mm
No
CBB021M12FM3
FM
Full-Bridge
48 A
21 mΩ
Gen 3 MOS
150 °C
62.8 x 33.8 mm
No
FM
30 A
21 mΩ
Gen 3 MOS
150 °C
62.8 x 33.8 mm
CBB021M12FM3T
FM
Full-Bridge
48 A
21 mΩ
Gen 3 MOS
150 °C
62.8 x 33.8 mm
CCB032M12FM3
FM
30 A
32 mΩ
Gen 3 MOS
150 °C
62.8 x 33.8 mm
No
CBB032M12FM3
FM
Full-Bridge
37 A
32 mΩ
Gen 3 MOS
150 °C
62.8 x 33.8 mm
No
CCB032M12FM3T
FM
30 A
32 mΩ
Gen 3 MOS
150 °C
62.8 x 33.8 mm
CBB032M12FM3T
FM
Full-Bridge
37 A
32 mΩ
Gen 3 MOS
150 °C
62.8 x 33.8 mm
CAB5R0A23GM4
GM
2300 V
200 A
5 mΩ
Gen 4 MOS
150 °C
62.8 x 56.7 mm
No
CAB5R0A23GM4T
GM
2300 V
200 A
5 mΩ
Gen 4 MOS
150 °C
62.8 x 56.7 mm
CAB6R0A23GM4
GM
2300 V
200 A
6 mΩ
Gen 4 MOS
150 °C
62.8 x 56.7 mm
No
CAB6R0A23GM4T
GM
2300 V
200 A
6 mΩ
Gen 4 MOS
150 °C
62.8 x 56.7 mm
CAB7R5A23GM4
GM
2300 V
170 A
7.5 mΩ
Gen 4 MOS
150 °C
62.8 x 56.7 mm
No
CAB7R5A23GM4T
GM
2300 V
170 A
7.5 mΩ
Gen 4 MOS
150 °C
62.8 x 56.7 mm
End of Section
  • Leading silicon carbide MOSFET technology in an industry standard form factor
  • Highest current rated topologies versus market equivalents
  • Built in NTC
  • Press-Fit connections
  • Ease of layout and assembly
  • System scalability and reliability
  • Discrete design consolidated into a single package
  • Increased power density / reduced system size
  • EV Fast Charging
  • Industrial Power
  • UPS
  • Induction Heating Welding
  • Power Supplies
  • Solar & Renewable Energy
  • DC/DC Converter
PRD-07968: Wolfspeed WolfPACK™ Dynamic Performance
PRD-02302: Wolfspeed Wolfpack Mounting Instructions & PCB Requirements User Guide
CCB016M12GM3
CAB008A12GM3
CAB008M12GM3
CAB006A12GM3
CAB006M12GM3
CBB032M12FM3
CAB016M12FM3
CAB011M12FM3
CCB032M12FM3
CCB021M12FM3
CAB004M12GM4
CHB011M12GM4
CBB011M12GM4
CBB021M12FM3
04/2023
PRD-08333: Wolfspeed Module CIL Evaluation Kits User Guide
PRD-09035: Wolfspeed Power Module RC Thermal Models User Guide
PRD-07561: CRD07500AA12N-FMC 7.5 kW Motor Drive User Guide
PRD-06992: CGD1700HB2M-UNA Dual Channel Differential Isolated Half Bridge Gate Driver Board User Guide
09/2023
PRD-07845: Power Module Baseplate Capacitance and Electromagnetic Compatibility
PRD-08911: Considerations for Current Balancing in Paralleled SiC Power Modules
PRD-04814: Design Options for Wolfspeed® Silicon Carbide MOSFET Gate Bias Power Supplies
PRD-08907: Mitigating EMI with SiC Solutions in Renewable Energy & Grid-Connected Power Converters
Wolfspeed WolfPACK™ Videos
Now Playing: WolfPACK™ Technical Video
Low Voltage Industrial Drives
