Wolfspeed WolfPACK™ Silicon Carbide Power Module Family
Silicon Carbide Implementation Made Simple, Compact, Reliable
Wolfspeed has launched a baseplate-less module family to meet the requirements of medium power applications, providing solutions across the power electronics continuum. Wolfspeed WolfPACK™ modules are a great choice for designers who want to increase efficiency and power density in a compact, industry standard footprint. The family of modules provide an excellent solution for fast design implementation, scalability, long term design support, and lower assembly overhead. Wolfspeed WolfPACK modules are currently available in half-bridge, six-pack, and full-bridge configurations all with the option of pre-applied thermal interface material.
Products
No filters selected, showing all 24 products
Wolfspeed WolfPACK™ Silicon Carbide Power Module Family - Filter By
Configuration
Maximum Junction Temperature
Module Size
Recommended For New Design?
CAB006M12GM3
GM3
Half-Bridge
200 A
6 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
GM3
Half Bridge (AlN substrate)
200 A
6 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
GM3
Half-Bridge
200 A
6 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
GM3
200 A
6 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
GM3
181 A
8 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
GM3
Half-Bridge
160 A
8 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
GM3
Half-Bridge
160 A
8 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
GM3
181 A
8 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
FM3
Half-Bridge
117 A
11 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
FM3
Half-Bridge
117 A
11 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
GM3
Half-Bridge
141 A
11 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
CAB011A12GM3T
GM3
Half-Bridge
141 A
11 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
FM3
Half-Bridge
84 A
16 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
FM3
Half-Bridge
84 A
16 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
GM3
Six-pack (three-phase)
50 A
16 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
GM3
50 A
16 mΩ
Gen 3 MOS
150 °C
62.8 mm x 56.7 mm
FM3
30 A
21 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
FM3
Full-Bridge
48 A
21 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
FM3
30 A
21 mΩ
150 °C
62.8 mm x 33.8 mm
FM3
Full-Bridge
48 A
21 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
FM3
30 A
32 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
FM3
Full-Bridge
37 A
32 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
FM3
30 A
32 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
FM3
Full-Bridge
37 A
32 mΩ
Gen 3 MOS
150 °C
62.8 mm x 33.8 mm
  • Leading silicon carbide MOSFET technology in an industry standard form factor
  • Highest current rated topologies versus market equivalents
  • Built in NTC
  • Press-Fit connections
  • Ease of layout and assembly
  • System scalability and reliability
  • Discrete design consolidated into a single package
  • Increased power density / reduced system size
  • EV Fast Charging
  • Industrial Power
  • UPS
  • Induction Heating Welding
  • Power Supplies
  • Solar & Renewable Energy
  • DC/DC Converter
Wolfspeed WolfPACK™ Videos
WolfPACK™ Technical Video
Videos
Videos
This document details the production packaging details including container type, quantity, MOQ, and dimensions as well as the moisture sensitivity level (MSL) for discrete SiC Schottky Diodes and MOSFETs
02/2024
View Now  Videos
Register Now  Webinars
