Announcing the Wolfspeed 650V Series of SiC MOSFETs
Designed to withstand the demands of today’s high-powered applications
Wolfspeed is pleased to announce its new 15-mΩ and 60-mΩ 650V Silicon Carbide (SiC) MOSFETs, which incorporate the latest C3M™ Silicon Carbide technology to offer the industry’s lowest on-state resistances and switching losses for higher-efficiency and power-dense solutions. While modern applications have increased demands for both efficiency and performance, Wolfspeed’s 650V SiC MOSFETs are up to the challenge. The family of 650V SiC MOSFETs from Wolfspeed features enable:
High Efficiency
- Low switching losses
- Low conduction losses
- Low reverse-recovery losses
High Power Density
- Lighter weight
- Smaller footprint
- Fewer Components
High efficiency
C3M0060065K vs Competition in a Boost Converter
![](/static/95b6c2e7d10c521559354b7420870bd8/4281a/650V-Synchronous-DC-DC-Boost-Converter.jpg)
Industry-leading Performance: SiC vs SiC
![](/static/795935aec5b395ceb3a2f2d711f6f176/a9d79/650V-Industry-leading-Performance-Graph.jpg)
High power density
![](/static/06ec89b7852f128f1e73e57518db3c65/ae285/Power-Density-image.jpg)
System Cost Comparison
![](/static/1cf96420db19765ee5452ed3852d565c/78d4b/650V-System-Cost-Comparison-2-1.jpg)
Wolfspeed 650V SiC MOSFETs vs. Competing Technologies
When it comes to performance, Wolfspeed Silicon Carbide is in a class of its own. Whether it’s in comparison to traditional silicon solutions or competitors’ Silicon Carbide products, Wolfspeed shines.
650V SiC vs. Silicon
- 1/2 the conduction losses
- 4,000% lower body diode reverse-recovery charge
- 75% lower switching losses, enabling higher efficiencies at higher frequencies
- Up to 70% greater power density
- Superior thermal performance
650V SiC vs. GaN on Silicon
- Over 1/2 the conduction losses
- Only industry-standard packages
- Robust gate drive
- Field-proven reliability
- Avalanche capability
Wolfspeed 650V SiC vs Competing SiC
- Industry’s lowest on-resistance increase over operating temperature
- Low output capacitance
- High switching frequency
- Easy to drive
650V MOSFET applications
Wolfspeed’s 650V SiC MOSFETs are built for the demands of today’s cutting-edge technology. From onboard chargers (OBCs) in electric vehicles (EVs) to uninterruptible power supplies (UPSes) and micro-inverters, Wolfspeed’s 650V SiC MOSFETs are rugged enough, reliable enough, and powerful enough for all applications:
Products
Products
Product SKU | Buy Online | Request Sample | Data Sheet | Blocking Voltage | RDS(ON) at 25°C | Generation | Current Rating | Gate Charge Total | Output Capacitance | Total Power Dissipation (PTOT) | Maximum Junction Temperature | Package | Qualification |
650 V | 25 mΩ | Gen 3 | 77 A | 111 nC | 186 pF | 326 W | 175 °C | TOLL | Industrial | ||||
650 V | 45 mΩ | Gen 3 | 49 A | 59 nC | 101 pF | 164 W | 175 °C | TOLL | Industrial | ||||
650 V | 60 mΩ | Gen 3 | 39 A | 46 nC | 72 pF | 131 W | 175 °C | TOLL | Industrial | ||||
650 V | 120 mΩ | Gen 3 | 21 A | 26 nC | 45 pF | 86 W | 175 °C | TOLL | Industrial | ||||
650 V | 25 mΩ | Gen 3 | 80 A | 109 nC | 178 pF | 271 W | 175 °C | TO-263-7 XL | Industrial | ||||
650 V | 60 mΩ | Gen 3 | 36 A | 46 nC | 80 pF | 136 W | 175 °C | TO-263-7 | Industrial | ||||
650 V | 60 mΩ | Gen 3 | 37 A | 46 nC | 80 pF | 150 W | 175 °C | TO-247-4 | Industrial | ||||
650 V | 60 mΩ | Gen 3 | 29 A | 46 nC | 80 pF | 150 W | 175 °C | TO-247-3 | Industrial | ||||
650 V | 15 mΩ | Gen 3 | 120 A | 188 nC | 289 pF | 416 W | 175 °C | TO-247-4 | Industrial | ||||
650 V | 15 mΩ | Gen 3 | 120 A | 188 nC | 289 pF | 416 W | 175 °C | TO-247-3 | Industrial | ||||
650 V | 120 mΩ | Gen 3 | 22 A | 28 nC | 45 pF | 98 W | 175 °C | TO-247-4 | Industrial | ||||
650 V | 120 mΩ | Gen 3 | 21 A | 26 nC | 45 pF | 86 W | 175 °C | TO-263-7 | Industrial | ||||
650 V | 120 mΩ | Gen 3 | 22 A | 28 nC | 45 pF | 98 W | 175 °C | TO-247-3 | Industrial | ||||
650 V | 45 mΩ | Gen 3 | 49 A | 63 nC | 101 pF | 176 W | 175 °C | TO-247-4 | Industrial | ||||
650 V | 45 mΩ | Gen 3 | 49 A | 63 nC | 101 pF | 176 W | 175 °C | TO-247-3 | Industrial | ||||
650 V | 25 mΩ | Gen 3 | 97 A | 112 nC | 178 pF | 326 W | 175 °C | TO-247-4 | Industrial | ||||
650 V | 25 mΩ | Gen 3 | 97 A | 108 nC | 178 pF | 325 W | 175 °C | TO-247-3 | Industrial | ||||
650 V | 45 mΩ | Gen 3 | 47 A | 61 nC | 101 pF | 147 W | 175 °C | TO-263-7 XL | Industrial |
Reference Designs
Explore Wolfspeed’s 650V SiC MOSFETs, companion parts, and reference designs to learn more about how SiC MOSFET technology from Wolfspeed can help you build better products that are up for the demands of today’s modern devices.
Products
Products
Name | Buy Online | Topology | Status | Package | Product SKU | View Product |
Dynamic Characterization | Available for Purchase | FM | KIT-CRD-CIL12N-FMC | |||
Dynamic Characterization | Available for Purchase | FM | KIT-CRD-CIL12N-FMA | |||
Available for Purchase | FM, GM, SpeedVal Kit | CGD1700HB2M-UNA | ||||
FM, GM, SpeedVal Kit | EVAL-ADUM4146WHB1Z | |||||
FM, GM, SpeedVal Kit | Si823H-ACWA-KIT |
