Off-Board Electric Vehicle Charger Plugged into EV
Renewable Energy
Fast Charging
By replacing traditional Si components with Wolfspeed Silicon Carbide upgrades, DC fast charger designs can realize significant gains in system efficiency, power density, and reliability.
Silicon Carbide is powering the future for Electric Vehicle Fast Charging
Fast charging DC stations can charge Electric Vehicles in just 30 minutes by bypassing the onboard charger (OBC) for rapid, direct battery charging.
Wolfspeed  CRD-22AD12N - 22kW Bi-directional High Efficiency Active Front End (AFE) Converter
Wolfspeed's 22kW Bi-directional High Efficiency Active Front End (AFE) Converter Reference Design
Power Up Faster with Off-Board DC Fast-Charging Technology
When drivers of electric vehicles (EVs) need a charge while on the go, the best option is off-board DC fast chargers, which enable rapid charging of EV batteries. Unfortunately, traditional silicon’s (Si’s) switching performance is limited, which means that even the fastest of Si-based chargers is still going to be too slow for the average consumer’s expectation. Alternatively, Silicon Carbide (SiC) and its unique physical properties enable superior switching speed and higher power delivery— which means an efficient charge.
Off-Board DC Fast Charger diagram showing how power is converted from AC Source to the EV Battery
Featured Discrete Silicon Carbide MOSFETs for Fast Chargers
No filters selected, showing all 15 products
Gate Charge Total
C3M0075120J
75 mΩ
30 A
51 nC
58 pF
113.6 W
150 °C
C3M0075120D
75 mΩ
30 A
54 nC
58 pF
113.6 W
150 °C
TO-247-3
C3M0075120K
75 mΩ
32 A
51 nC
58 pF
113.6 W
150 °C
C3M0045065J1
47 A
61 nC
101 pF
147 W
TO-263-7 XL
32 mΩ
63 A
118 nC
129 pF
283 W
C3M0032120D
32 mΩ
63 A
114 nC
129 pF
283 W
TO-247-3
C3M0040120J1
40 mΩ
64 A
61 nC
94 pF
272 W
150 °C
TO-263-7 XL
C3M0040120D
40 mΩ
66 A
101 nC
103 pF
326 W
TO-247-3
C3M0040120K
40 mΩ
66 A
99 nC
103 pF
326 W
C3M0032120J1
32 mΩ
68 A
111 nC
133 pF
277 W
150 °C
TO-263-7 XL
C3M0025065J1
25 mΩ
80 A
109 nC
178 pF
271 W
TO-263-7 XL
C3M0021120D
21 mΩ
81 A
160 nC
180 pF
469 W
TO-247-3
C3M0021120K
21 mΩ
100 A
162 nC
180 pF
469 W
C3M0016120D
16 mΩ
115 A
207 nC
230 pF
556 W
TO-247-3
C3M0016120K
16 mΩ
115 A
211 nC
230 pF
556 W
Featured Discrete Silicon Carbide Schottky Diodes for Fast Chargers
No filters selected, showing all 7 products
Forward Voltage(VF(type))
E3D08065G
8 A
1.5 V
8 A
50 nC
176 W
TO-263-2
C6D10065A
10 A
Gen 6
1.27 V
10 A
35 nC
109 W
TO-220-2
C6D10065E
10 A
Gen 6
1.27 V
10 A
34 nC
99 W
TO-252-2
C6D16065D
16 A
Gen 6
1.27 V
16 A
29 nC
100 W
TO-247-3
C6D20065D
20 A
Gen 6
1.27 V
20 A
35 nC
116 W
TO-247-3
E3D20065D
20 A
1.5 V
20 A
110 nC
250 W
TO-247-3
E3D30065D
30 A
1.5 V
30 A
43 nC
179 W
TO-247-3
Wolfspeed WolfPACK™ Silicon Carbide Power Modules
Wolfspeed Silicon Carbide power modules can enable a simpler fast charging circuit topology using fewer components at very high efficiency (97.0% peak), switching at more than twice the frequency (45-250kHz). The higher frequency allows smaller magnetics and capacitors which, in turn, accounts for the smaller, lighter, and less costly system.
Wolfspeed WolfPACK™ FM3 and GM3 power modules are ideal for mid-power applications, including EV fast charging. The modules come in MOSFET half-bridge and six-pack configurations with a variety of mΩ options. The devices feature a baseplateless design, compact footprint, and press-fit pins, providing efficient, powerful performance while keeping system layouts straightforward for design and assembly processes.
The product family includes high performance Aluminum Nitride (AlN) substrate modules, which can reduce thermal resistance by over 50% and provide 7x higher thermal conductivity compared to Alumina.
Featured WolfPACK™ Silicon Carbide Power Modules for Fast Chargers
No filters selected, showing all 42 products
Configuration
Module Size
CAB004M12GM4
GM
Half-Bridge
200 A
4 mΩ
62.8 x 56.7 mm
CAB004M12GM4T
GM
Half-Bridge
200 A
4 mΩ
62.8 x 56.7 mm
CAB004A12GM4T
GM
Half Bridge (AlN substrate)
200 A
4.1 mΩ
150 °C
62.8 x 56.7 mm
CAB004A12GM4
GM
200 A
4.1 mΩ
150 °C
62.8 x 56.7 mm
CAB5R0A23GM4
GM
2300 V
200 A
5 mΩ
150 °C
62.8 x 56.7 mm
CAB5R0A23GM4T
GM
2300 V
200 A
5 mΩ
150 °C
62.8 x 56.7 mm
CAB006A12GM4
GM
200 A
5.5 mΩ
150 °C
62.8 x 56.7 mm
CAB006A12GM4T
GM
200 A
5.5 mΩ
150 °C
62.8 x 56.7 mm
CAB006M12GM3
GM
Half-Bridge
200 A
6 mΩ
62.8 x 56.7 mm
CAB006A12GM3
GM
200 A
6 mΩ
62.8 x 56.7 mm
CAB006M12GM3T
GM
Half-Bridge
200 A
6 mΩ
62.8 x 56.7 mm
CAB006A12GM3T
GM
200 A
6 mΩ
62.8 x 56.7 mm
CAB6R0A23GM4
GM
2300 V
200 A
6 mΩ
150 °C
62.8 x 56.7 mm
CAB6R0A23GM4T
GM
2300 V
200 A
6 mΩ
150 °C
62.8 x 56.7 mm
CAB7R5A23GM4
GM
2300 V
170 A
7.5 mΩ
150 °C
62.8 x 56.7 mm
CAB7R5A23GM4T
GM
2300 V
170 A
7.5 mΩ
150 °C
62.8 x 56.7 mm
CAB008A12GM3
GM
181 A
8 mΩ
62.8 x 56.7 mm
CAB008M12GM3
GM
Half-Bridge
160 A
8 mΩ
62.8 x 56.7 mm
CAB008M12GM3T
GM
Half-Bridge
160 A
8 mΩ
62.8 x 56.7 mm
CAB008A12GM3T
GM
181 A
8 mΩ
62.8 x 56.7 mm
CAB011M12FM3
FM
Half-Bridge
117 A
11 mΩ
62.8 mm x 33.8 mm
CAB011M12FM3T
FM
Half-Bridge
117 A
11 mΩ
62.8 mm x 33.8 mm
CAB011A12GM3
GM
Half-Bridge
141 A
11 mΩ
62.8 x 56.7 mm
CAB011A12GM3T
GM
Half-Bridge
141 A
11 mΩ
62.8 x 56.7 mm
CBB011M12GM4
GM
Full-Bridge
100 A
11 mΩ
62.8 x 56.7 mm
CBB011M12GM4T
GM
Full-Bridge
100 A
11 mΩ
62.8 x 56.7 mm
CHB011M12GM4
GM
T-Type
100 A
11 mΩ
62.8 x 56.7 mm
CHB011M12GM4T
GM
T-Type
100 A
11 mΩ
62.8 x 56.7 mm
CAB016M12FM3
FM
Half-Bridge
84 A
16 mΩ
62.8 mm x 33.8 mm
CAB016M12FM3T
FM
Half-Bridge
84 A
16 mΩ
62.8 mm x 33.8 mm
CCB016M12GM3
GM
Six-pack (three-phase)
50 A
16 mΩ
62.8 x 56.7 mm
CCB016M12GM3T
GM
50 A
16 mΩ
62.8 x 56.7 mm
CBB017M12FM4
FM
Full-Bridge
50 A
17 mΩ
62.8 mm x 33.8 mm
CBB017M12FM4T
FM
Full-Bridge
50 A
17 mΩ
62.8 mm x 33.8 mm
CCB021M12FM3
FM
30 A
21 mΩ
62.8 mm x 33.8 mm
CBB021M12FM3
FM
Full-Bridge
48 A
21 mΩ
62.8 mm x 33.8 mm
FM
30 A
21 mΩ
62.8 mm x 33.8 mm
CBB021M12FM3T
FM
Full-Bridge
48 A
21 mΩ
62.8 mm x 33.8 mm
CCB032M12FM3
FM
30 A
32 mΩ
62.8 mm x 33.8 mm
CBB032M12FM3
FM
Full-Bridge
37 A
32 mΩ
62.8 mm x 33.8 mm
CCB032M12FM3T
FM
30 A
32 mΩ
62.8 mm x 33.8 mm
CBB032M12FM3T
FM
Full-Bridge
37 A
32 mΩ
62.8 mm x 33.8 mm
Featured Reference Designs for Fast Chargers
No filters selected, showing all 8 products
CRD-06600DD065N
6.6 kW High Frequency LLC
LLC
6.6kW
TO-247-3
C3M0060065D
C6D10065A
TIDA-01604
6.6 kW Bridgeless Totem-Pole PFC
Interleaved Totem-Pole PFC
6.6kW
TO-247-3, TO-247-4
C3M0065100K
Texas Instruments
TIDM-02002
6.6 kW Bi-Directional CLLLC
CLLLC
6.6kW
C3M0030090K
Texas Instruments
CRD-06600FF10N
6.6 kW Bi-Directional Totem-Pole PFC and CLLC, High Efficiency
AC to DC, DC to DC
6.6kW
C3M0065100K
CRD-06600FF065N-K
6.6 kW Bi-Directional Totem-Pole PFC and CLLC, High Power Density
AC to DC, DC to DC
6.6kW
TO-247-4, TO-247-3
C3M0060065K
C3M0060065D
TIDA-010054
10 kW Phase Shift DAB
DAB (Dual Active Bridge)
10kW
C3M0075120K​
C3M0030090K
Texas Instruments
CLLC
Gen 4 Silicon Carbide Technology:
Redefining Performance and Durability in High-Power Applications
